Machine Vision
imaqReadCustomData(..) failed
I am trying to read data matrix, by using the sample code in CVI2012. Instead of runing the source code, I created a new project, loaded one sample image (data matrix) , tried to get data matrix setting, but failed.
I don't know why the source code can successfully get this setting, but I cannot. The only difference is that I read just one image, instead of all the sample images one time. Cat Frustrated
Checked the help file, found the description for function (imaqReadCustomData) is very poor noted.
Can someone show me what is the problem?
Thank you very much.
(5,629 Views)
Supplement Info:
1) Had an image, 1.png, for example, I can read data matrix in NI Vision Assistant 2012;
2) Using imaqWiteFile(..) to save 1.png to 1.bmp, try 1.bmp in NI Vision Assistant, I can read the data matrix also;
3) Use imaqReadFile(..) to load file 1.bmp in my code, When it runs to imaqReadCustomerData(..) it will failed;
4) Use imaqReadVisionFile(..) to load 1.png, it works well.
Don't know why, does it any limit in read data matrix, for example, only support *.png image file?
Please help.
(5,619 Views)
Accepted by yuzaihuan
Based on your findings you are facing issues with using imaqReadCustomData and not with imaqReadDataMatrixBarcode API.
imaqReadCustomData is used for reading custom data (ROI, cluster of parameters or anything) from NI Vision image. Only png files are supported for writing and reading the custom data to/from disk.
If you need to read custom data from an image file (in this case it is data matrix parameters), the file should have been loaded with imaqReadVisionFile so that it reads image data and custom data while loading from disk.
imaqReadCustomData is not related to reading data matrix barcodes. It was just used to read the parametes stored in the example images. You could also provide another set of parameters instead of using stored parameters. Please use Vision Assistant to come up with parameter set.
Hope this helps.
Antony
(5,591 Views)
You are right: Only png files are supported for writing and reading the custom data to/from disk.
I will try to use other set of parameters, instead of from the image file.
(5,578 Views)
