11-22-2011 07:25 AM
I am using an AVT Pike F-145B under windows7 (32bits). With Measurement and Automation Explorer 4.7.7 I can grab images if I use another video mode than format 7, mode 0 (which is the video mode I need!). If I use this video mode (format 7, mode0, 1388x1038), it is as if something was not well synchronized and the acquired frames are mixed up.
Does someone has a clue for this issue?
11-23-2011 07:24 AM
Hello Gege91,
Are you using the latest driver available in order to be sure that it's not coming from that point. Did you try it also another computer?
Regards
Mathieu B
National Instruments France
11-23-2011 07:48 AM
I installed NI Vision Acquisition Software March 2011. And I've already tried this camera with another computer but under WinXP, I do not have another computer under win7 available now for further tests.
I think I will try to use my camera with AVT SmartView and see if there still is something wrong.
Regards
11-23-2011 08:54 AM
I've just noticed I am always using my camera with "PacketSize"=4095 bytes, I've tried other values and while this parameter is smaller than ~4016, I do not have my problem anymore.
Is that because I am using an IEEE1394b camera with IEEE1394a on my computer?
I've never had this sort of trouble under Windows XP...
