Machine Vision
install the driver of IEEE-1394 (Firewire) camera
I ve developped a vision application on VBAI. After that I migrated it to LabVIEW.
The problem that The application is not repetetive. After some times, It returns an error. To solve this problem I reinstall the driver of the camera from max. Why this happen? and what shall i do?
Message 1 of 9
(5,182 Views)
What is the error? You can turn on highlight execution to see where the error is coming from and track it down to the specific step throwing the error. This would be helpful information.
Brad
Message 2 of 9
(5,181 Views)
After re-installing the error is not occuring?
Message 3 of 9
(5,179 Views)
yes. After installing the cam the vi execute correctly. After some time I need to reinstall the cam although I didn't touch the cam neither the cable.
Message 4 of 9
(5,167 Views)
It an error related to acquisition
Message 5 of 9
(5,162 Views)
Do you use any registry cleaner utilities? As this utilitiy may remove your driver. Also check if you use a decent antivirus.
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
Message 6 of 9
(5,151 Views)
What exactly do you mean by reinstall the driver from MAX? Is this a real-time target? Or are you just reselecting the driver in MAX?
Jeff | LabVIEW Software Engineer
Message 7 of 9
(5,134 Views)
I just reselect the driver
Message 8 of 9
(5,126 Views)
It sounds like you were using the old 1394 driver at first, then started using IMAQdx in LabVIEW. Once you select the right driver it'll work.
Message 9 of 9
(5,113 Views)
