Machine Vision
isotropic kernel
Hi everyone!!!
hehe.. Does anyone know how to implement an isotropic kernel, with a convex and monotonic decreasing kernel profile, over an image?
thx!!
(4,599 Views)
Could you clarify what you are trying to do and please define how you are using the terms 'isotropic kernel', 'convex', and 'monotonic'. A kernel normally implies a set of all elements of one group which are mapped to a identity elements of another group. Are you trying to modify the pixel values of an image based upon a mathematical function with the proposed kernels (i.e. : a custom filter)?
After a little research, I found the following link that describes a method of using a Gaussian isotropic kernel for low pass image filtering (refer to section 3.5). Perhaps this will help.
http://www.imm.dtu.dk/~jmc/02501/exercises/filtering/filtering.pdf
(4,586 Views)
