ā11-22-2016 07:17 AM
hi,
i want know about camera on status while run time un plug the camera(usb cable).i attached vi and camera setting and model information.
a).i am using camera trigger mode
ā11-22-2016 02:06 PM
ā11-22-2016 10:22 PM
yes, i want know about when camera cable is unpluged.but my while loop is runiing continuously it give time out error.
ā11-22-2016 11:53 PM
use this vi it will help you
ā11-23-2016 01:31 AM
this is not working because camera is trigger mode so it give if the camera connected time also time out error.so it toggling plug and unplug.
ā11-23-2016 02:30 AM
I add loop to your vi that check if your camera is conect or not check this vi may be it could help
ā11-23-2016 03:17 AM
if camera is conneted or not connected it always give is same setting(array zero index data only).
ā11-23-2016 04:53 AM
ā11-23-2016 05:00 AM
yes i accepts that but defaulty came same setting when connect or not conneted both the condition.
ā11-23-2016 07:26 AM
