Machine Vision
legacy imaq1394 acquisition not working anymore giving error -50353
Hello again,
I should add: after re-installing the VAQ 8.6 driver package, the error message changed to "Not enough Memory" (with a very long number as error code).
Also I should mention that another Image Aquisition program, which was delivered with the camera, still works fine.
P. Bohr
Message 11 of 15
(3,227 Views)
P Bohr,
What image size are you trying to acquire? Also, how many images are you acquiring in your sequence? If you reduce either number, does that help?
Eric
Message 12 of 15
(3,203 Views)
the images are around 200 x 700 pixel, slightly above 100 kB in size, if I remember corretly (they're taken by using mono-8 pixels). Aquiring a max. of 400 is possible, more produces the said error, as I have found out.
P. Bohr
Message 13 of 15
(3,180 Views)
I also have the related error code -50353. While I was using NI Thermocouple to get the temperature values from 8 channel of device, I got a the error -50353 after some executions. I am using While loop to get the values continuously.
Why do you think ı got this error?
Message 14 of 15
(2,896 Views)
Also, As ı look up, I saw that Labview is using increasing memory space . The program starts with about 140MB of memory usage. Then it crashes with error code -50353 when it is using at about 750MB of RAM space.
How can I handle this?
Could you help me?
Message 15 of 15
(2,893 Views)
