Machine Vision
machine vision
Need help in positioning the servo motor corerresponding to the object detected in camera. need to know how to convert camera pixels to duty cycle  of servo motor.
an object is detected in camera  then the servo must move the camera such that the object is in the centre position of the camera.
Thanks & Regards,
Bharath Kumar
GCentral
(4,477 Views)
You need to try moving a servo, and see how many pixel moves per encoder pulses? From that, you can calculate back how to control position for such purpose.
(4,473 Views)
