Machine Vision
measure diameter (tickhness) from binairy picture
Message 21 of 64
(3,040 Views)
Kevin,
I get this message
Message 22 of 64
(3,027 Views)
Message 23 of 64
(3,028 Views)
Kevin's program works fine for me 🙂
I've made 2 program's now, the one with circel detection, and added a layer wichs gives the thickness on every
circel. And a program wich works with edge detection, but the user must define the line, so
that one doesn't qualify for my demands.
Today I'll speak with my compangion, so I willl see if this is good enough for him!
I added my program, just for fun 🙂
Message 24 of 64
(3,018 Views)
If solved, Markthe post that helped as the solution..:smileywink:
Message 25 of 64
(3,005 Views)
I just discussed the program with my compagnion.
At first I don't quite know how the program works, the following question popped up:
Why aren't there in the entire image circles and in some vains there are fewer circels
then in other vains? Is it possible to have the same ammount of circel in every vain?
Does anyone know a site where I can see what circel precisly does?
Thanks!
Message 26 of 64
(3,000 Views)
Thanks!
Maybe it is not possible to fit a circle on that irregular region...
Message 27 of 64
(2,995 Views)
Ok 🙂
Message 28 of 64
(2,993 Views)
Is it possible to program imaq distance so it will use more than 15 colors?
Or isn't that possible?
Message 29 of 64
(2,964 Views)
Accepted by topic author Chantal
Ni recommends using IMAQ Danielsson VI instead of distance. Doesnt the color depend on your image?
Message 30 of 64
(2,958 Views)
