Machine Vision
measure diameter (tickhness) from binairy picture
that's what I'm using now 🙂
but it only uses 15 colors in al my images
Message 31 of 64
(2,245 Views)
The values produced by the Danielsson algorithm will go up to the limit of your image (255), but the binary display palette rotates through 15 colors and reuses colors for different values.
You could generate your own custom palette, or you could try some other palettes.  The rainbow and gradient palettes might look cool.
Bruce
Bruce Ammons
Ammons Engineering
Message 32 of 64
(2,230 Views)
How can I generate my own custum palette? there's no entrance for a palette?
Message 33 of 64
(2,210 Views)
Message 34 of 64
(2,209 Views)
It doesn't work, if I create my own pallete it still uses the 15 colors....
Message 35 of 64
(2,207 Views)
ow got it!
Thanks 🙂
Message 36 of 64
(2,206 Views)
Any update on the thickness measurement?
Message 37 of 64
(2,204 Views)
I'm almost there 🙂
Should I post it as solved? or can I wait until I've really solved it myself?
Message 38 of 64
(2,202 Views)
I f you have solved it mark the post that helped you as the solution. Might help someone in the future.
Message 39 of 64
(2,198 Views)
I've got some new questions, In the attachment is my program so far.
There are some new problems, I've used the function skeletonize, only
this function doesn't work the way I want, I thought it would look at
the vains and draw a line in the middle of the vain but there are a lot of
side vains which there aren't at the normal picture. How can I solve this?
I also thought up another function, but I don't know if that exist.
Does anyone know if there is a reversed danielson function? if there is
I would like to know!
Thanks!
Message 40 of 64
(2,140 Views)
