09-22-2005 11:43 AM
09-23-2005 05:28 PM
10-26-2005 10:54 AM
10-28-2005 08:27 AM
You probably are not seeing correct images because of all of the Image type conversions, I created an example VI in LabVIEW 7.1 with a few of the Vision Development Module functions. The zip file also has a sample signed 16 bit image (unsigned 16 bit images are not currently supported) and a RGB image.
Hopefully this helps out!
