Machine Vision
missing imaq vis when deploying a vision app
I have an application using LabVIEW 7.1 IMAQ 2.6.3, Vision 7.1.1 and Vision Builder for Automated inspection.  Everything works great until I try to build an exe and install it on a second machine.  I've installed IMAQ 2.6.3 and I've purchased the Vision Deployment Engine and installed the Vision Runtime Engine on the target machine.  However, when I try to run my exe, it says it can't find all sorts of vision-related VIs (imaq this or that.vi, etc...).  Interesting thing is that when I inserted the Vision Deployment Engine CD and selected "Install Runtime Engine", it imediately came back and said it had finished - no install shield, no nothing - and no activation?!  Yet when I look at my installed applications in Windows, it shows that the Vision Runtime Engine is indeed installed.  I tried un-installing it and re-installing it - same result.
(3,181 Views)
Have you activated the license?  I think that there is a license manager entry for the Vision Deployment Engine.  It's been a while so I may be remembering something wrong.
Bob Young
(3,178 Views)
