Machine Vision
noncontinuable exception error opening camera file
Hi.
I'm trying to open a camera file I generated in Camera FIle Generator in MAX. I keep getting an exception error with the popup of submitting an error report. (I actually have problems with 2 camera files, but I'm thinking the problems are related.)
In Camera File Generator, I can connect to the camera and see video. The camera is an Allied Vision Bonito CL 400B-200fps. We have a NI PCIe-1429 Cameralink card.
WIn-7 64-bit, but MAX and Camera File Generator are both 32-bit. (Maybe this is the problem?)
- How do I find out what is wrong with the camera file.
-  This is on a non-networked machine, so how do I submit it a crash report?
Thanks for any help.
(5,444 Views)
Accepted by tjwilli58
Scott here with Allied Vision.   While I'm not our leading Bonito techy, I'm in the team of support colleagues who are.  And I'm the one with the NI Forum account, so I'm happy to be the liaison on this.   Paraphrasing from my colleague:
BEGIN
If the NI grabber driver is 32 bit, inside the win64 system it should not be a problem.
The camera file Generator is not perfect, suggest using a camera file from us.
( File
     “AVT Bonito CL-400 1x2320 [CL][GrabberClock].icd”
from
    https://alliedvisiontec.box.com/s/6t1myjoj5qh72ayn9bvgqdpknwqxkd8i
END
Please try this and advise if that gets you over the hump?
FYI for "Allied Vision specific" questions you may contact Allied Vision support via http://www.alliedvision.com/en/support/contact-support-and-repair.html
Of course for NI-specific topics please focus on NI support and forums.
Hope this helps!
Scott
(5,399 Views)
Thanks so much!  This worked like a charm. I did a diff on my camera file and the AVT Bonito CL-400 [CL][GrabberClock].icd file. to see what was causing the problem. Once I copied the Attribute section over to my icd file, MAX didn't crash when I tried to open it.
I'm having the same problem with a Sofradir MiTIE LWIR camera file that I was told worked on another machine. It also didn't have camera attributes. I'll see if I can download another camera file for that camera.
(5,377 Views)
Glad that did the trick!  Thanks for the closure.
Scott
(5,373 Views)
