Machine Vision
one trigger to take multi images
Hi All,
I am using a Guppy Pro F031b, which is equiped with Bulk Trigger Mode.  This mode allow me to take multipule frames with one external trigger.
I want to take two image every trigger and save them.  But I have no idea how to realize this function with with IMAQdx.  Has anyone did this before and can give me a hand?
Shall I use Grab or "IMAQ get image"?  Shall I use a whileloop to let the get image excuated twice or the VI will automatically grab two image?
Thank you very much!
Wen
(5,678 Views)
xu27,
What have you tried so far?
(5,651 Views)
Hi Wen,
Try using IMAQdx Grab to do this, but with an infinite timeout.  That way, when you hit the IMAQ Grab function, it will block until it receives a full image from the camera.  This means it will wait until the camera receives the trigger and begins outputting images to acquire.  I would start with the basic Grab.vi example availale in the IMAQdx>High-Level directory in the Example Finder.
Cody A.
(5,648 Views)
Accepted by xu27
Cody A., Kyle T. ,
I have already programed a VI include trigger mode 0(edge triger), trigger mode 1(level trigger), and bulk  trigger.  I monitored the camera IO which can show me the camera exposure time. And I found after every trigger, the camera does exposure twice.
Shall I set the buffer number as 2 if I want to use bulk trigger?
How can I read out the two images in my buffer?
(5,629 Views)
Hi XU27,
Is it possible if you can share the VI .
Thank you .
(4,639 Views)
