Machine Vision
problem about overlay
Why cant overlay text on the image? when program run,the image only display text and black background,in fact i want to overlay the text on the RGB iamge.please help,thanks.
(3,688 Views)
You forget to enclose the "IVA GrayFilter.vi" so I removed it and when running our VI I was receiving an error that says the image is too small to perform the convolute operation, so I also removed the "convolute" and here is the result I got :
just to show you, here is a screen-shot of the code :
Hope this helps
Message Edité par TiTou le 07-26-2007 12:10 PM
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,676 Views)
thanks TiTou
the IVA GrayFilter.vi was generated by vision assistant,  after i removed convolute, it works ,but not stable.
i add a "IMAQ creat" vi to the extractsinglecolorplan's image Dst ,then the hole programs works fine. Smiley Very Happy
(3,639 Views)
