Machine Vision
saving snapshot
I'm using Imaq 1394 cameras to take a live image.  I give the user the option to snap the image by turning off the live acquisition so that the las fram is left on the screen.  How can I give them the option of saving this file to disk?
I've tried using a local variable of the Image Control, but the resulting file is unreadable unless it is in live image mode...
Thanks in advance
(3,058 Views)
If you are beginning with LabVIEW and/or IMAQ there are a couple of "typical beginner's mistake" you should know about ; could you post the code you made so that we can give appropriate advice ?
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,049 Views)
