Machine Vision
problem in using vision assistant and the subVI
Dear labview user and Labview Engineer
I wan to to develop machine vision by using labview. Currently I can capture the image by using my camera and our capture2(1).vi. In other hand I also develop image processing algorithm by using machine vision assistant. After that we generates vi form the vision assistant. The image processing vi working well when using an image from file (using file path).
However when I tried to connect image processing.vi to the capture2(1).vi, I cannot get the measurement result and the output image.
Does any labview user can give me some suggestion to solve this problem?
herewith the capture2(1).vi, the vision assistant file, and screen shot of the front panel that shows problem to display the image from the sub vi
Thank you
Best regards
Sugeng
(3,339 Views)
Accepted by sugeng
Hi Sugeng,
I opened up the VI that you sent to the forum. Since I am unable to open the VI in question (Analysis subVI), I can't give you much pointer of why you didn't get the expected output. You may want to post the sub-VI so that we can give you better feedback.
Meanwhile, I also saw that you subVI doesn't follow recommendation to have all output connection from the Sub-VI located on the right side of the SubVI which may confused or misread your diagram. Do try to follow the recommendation so that your code can be more readable and maintainable.
Regards
- Meadow -
LabVIEW 7.0 - 2011, Vision, RT, FPGA
TestStand 3.0 - 4.5
(3,317 Views)
Hi Meadow
Thank you for you response to my problem.
Could you explain what do you mean with the recomendation is ?
Thank you
Sugeng
(3,303 Views)
It is recommended to have all outputs from a VI or subVI on its right side.
(3,299 Views)
