Machine Vision
publishing the "snap image from webcam" vi on web
hi
i have the vi for snapping an image from the webcam and storing it. I want to pusblish that vi on the web so that i can control it through internet. but the problem is that i cant see the images on the web browser. i can request the control on start the vi but cant see the images. please give some solution for this. i was using the web publishing tool.
thanx
abhiram
(3,484 Views)
Abhiram,
What type of VIs are you using to acquire your webcam image?  For example, are you using IMAQ functions, or the built in LabVIEW functions?  The way that you are implementing your LabVIEW code will help me find a solution for you.  Thanks.
Chris
(3,472 Views)
hai chris,
i am facing the same problem while publishing a VI by using Web publishing tool. Because i got the front panel of the Host system in remote client system & it can be controllable. but the image what i have diaplyed is not coming at the client side. i have enclosed the code. please acknowledge me.
thanks and regards,
Dinesh Anton Raja P
(3,003 Views)
