Machine Vision
Vision
Good evening , I need help to capture an object using a web cam, then detect the colors that are present in the captured object.
Does anyone have any Idéa or example that might help?
Thanks in advance.
(4,829 Views)
-For capturing you need NI Vision Acquisition Software.
-If you have Labview installed already you can check the examples provided for color detection.
-To access examples-Goto>>Help>>Find Examples>>Goto Search Tab and enter color.
-In the same you can access image capturing examples by entering "Grab" in Search tab.
uday
(4,820 Views)
