Machine Vision
multiple ROIs??
Hello!
i'm writing a program where i'll need to extract 6 ROIs for OCR from the same picture( Name ....)the regions i want to extract are in the picture selected (the rectangles in green),i've read that it's possible using ROI ungroup or ROI group,how can i do that?if you think there's an easier way any advice will be helpful,please feel free to reply if you have any questions. thanks in advance for your help.
(6,410 Views)
How do you want to extract them?manually? automatic using some reference?
(6,399 Views)
automatically,i want to choose the ROIs before so the user will only enter the picture
(6,391 Views)
yes, just use ungroup ROIs and for loop to perform OCR in the individual region.
I don't know how you've created the ROI's, but If you want them in a specific order you can sort them prior to recognition (for example, from smallest to largest top vertical coordinate).
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(6,374 Views)
thank you for your help,i haven't created the ROIs yet because i didn't know how i'll continue after that,how can i sort them?thank you in advance
(6,342 Views)
Hey Tmmed,
The sorting should be done by the auto indexed input and output tunnels of the for loop, so in the order that you select the ROIs they will input the for loop, then output the strings in the same order into an array.
Regards!
>>Daniel C.
(6,327 Views)
no matter how you create the ROI's you can sort them for example by the left global rectangle coordinate that describes the ROI:
You can use different sorting parameters, but it would involve a little bit more work.
K
(6,318 Views)
