Machine Vision
"IMAQdxOpenCamera" function execution time is particularly long,why?
I install VAS2011 in CVI2010 environment, running IMAQdx the samples  <Grab and AttributesSetup>,  "IMAQdxOpenCamera" function execution time is particularly long, more than 7 seconds,why?
Thanks!
Message 1 of 8
(4,647 Views)
Hi
Mention what type of camera you are using so that can help you better.
Silver_Shaper | CLD
Message 2 of 8
(4,645 Views)
 Type of the camerais a USB Camera, Camera support the  directshow。
Message 3 of 8
(4,639 Views)
Accepted by longd99
Hi
The problem is with the USB Camera only. Normally any USB cam takes this time because of its interface nature.
Silver_Shaper | CLD
Message 4 of 8
(4,636 Views)
Thank you for your answers!
I capture video using VFW initialization faster, only use IMAQdx speed slow.
thanks!
Message 5 of 8
(4,628 Views)
Hi
If you got answer mark the solution.
Silver_Shaper | CLD
Message 6 of 8
(4,626 Views)
My camera is Basler GigE,   and link 6 cameras.         use NI 2012
IMAQdxOpenCamera cost 10 seconds,   Why?
and I found it cost more time open one camera if more cameras link.
Message 7 of 8
(4,359 Views)
You will liklely find a significant speed increase by updating your version of Vision Acquisition (and the included IMAQdx driver). GenICam-based cameras such as GigE Vision ones use an industry software component called GenApi to parse the XML files from the camera. There have been notable speed increases in newer versions that speed up opening quite a bit.
Eric
Message 8 of 8
(4,356 Views)
