Machine Vision
rebuild programme
my source code is developed by labview 2012
now i want to upgrad the PC and OS,
can i used 2021 to rebuild the source code directly?
do i need bought the new run-time authorization for 2021
any suggestion,thanks
(2,096 Views)
Accepted by librazhou
-- in my experience you can rebuild the source code directly.... Most of the time....   Sometimes because of minor changes in VI library, small changes are required.
-  Runtime licenses are supposed to be perpetual, but if you switch hardware, you will likely have to de-register the machine the runtime is in, and reregister it to the new platform.
Hope this is correct, and helps.
(2,072 Views)
i am not sure before, now i will prepare it for try
thanks a lot
(2,050 Views)
