Machine Vision
recieve error message 1074397056 - IMAQ Create Bayer LUT.vi
I am receiving an error when I try to run the White Balance uitility for the Hitachi camera attached to my microscope.  The error states "1074397056 - IMAQ Create Bayer LUT.vi".  I thought that this might have something to do with the license activation, so I went through that process and obtained an Activation code.  However, the software would not accept the activation code.  I am a novice with this equipment and any help would be greatly appreciated.
(3,976 Views)
1074397056         IMG_ERR_BAD_BITS_PER_COMPONENT         The bits-per-component value is invalid.
This is what i got when i searched for the error code.
Can you attach some details?
(3,962 Views)
The description of the error lead me to look at what files I could open with the White Balance software.  It appears that I can only open files that are 8 bit.  I can not open any of the RGB (32 bit) files.  Only the single color files will open.
Another engineer tells me that this utility has never worked.  He has a work around that will get us by
(3,954 Views)
Can you share that work around?
(3,942 Views)
This is expected behavior. You are correct, you need to take only one color plane at a time and do your white balancing on each plane.Bruce does a great job explaining this here.
Does this help?
--Michelle
(3,935 Views)
Thanx for the link michelle,Bruce indeed has done a grt job
(3,927 Views)
Thank you for the information.
(3,906 Views)
