Machine Vision
scale invariant geometric pattern matching error
Find the template and vi
Message 21 of 29
(3,282 Views)
Are you able to open them. Helped?
Message 22 of 29
(3,281 Views)
No
I am unable to open the files. Over the wekend, I was able to match all the objects in
the image using vision assistant. As you guys I was lacking a proper template creation.
I did that and it worked.
I also wanted to ask you about how we can pattern match using line profile as you mentioned
in your last post.  I want to do whatever I did right now in color pattern matching. Is there
a way around it.
Message 23 of 29
(3,270 Views)
First why are you not able to view the vis. I have atatched the vis for lv 8.0? Do you require a screenshot?
Message 24 of 29
(3,247 Views)
Find the template geo from the previous post. From the pattern matching bounding box you can draw the line profile to get the details. I will show what exactly i meant in my next post
Message 25 of 29
(3,246 Views)
So now you got the steps?
Message 26 of 29
(3,213 Views)
Muks
thanks for your help. I havent tried your code yet but I have a working code of my own.
I will try your code 2morrow morning. I think you might have  got the IVa mask from ROI from
the vision assitant if I am right. But I fail to understand the concept behind entering those values
in the ROI window. thats the thing I failed to understand.
My other question is can I only extract all the matches in the image. The imaq extract doesnt have
angle with it. It just gives takes the global rectangle. Is there any proper way to extract the matched
template in the image. bcoz i can extract unrotated matched template image right now. I will put a
screen shot of what I did 2morrow.
thanks for your time anyway. If u live in NY I owe u a beer.
Message 27 of 29
(3,211 Views)
Accepted by topic author Arjun247
You can use a imaq rotate and use the pattern matched angle (360-this angle). To rotate the pattern and then extract. Y?es i did get that image mask from vision assistant.
Message 28 of 29
(3,207 Views)
If your problem is solved then mark the post that helped as "the solution"...:smileywink:
Message 29 of 29
(3,088 Views)
