Machine Vision
serial IO not working
hello guys,
my IO module which controls several relays and sensors through a rs485 to rs232 convertor, is not working with vision builder serial io step. it's working on its own interface but when I send the same command from vision buider it does not respond.
of course the commands on interface are on ascii code but vision builder sends hexadecimal so I converted the ascii codes to hexadecimal and it's not working.
the way i converted the code is this:
@011=40h 30h 31h 31h
so I sent 40303131 to the device instead of @011.
(3,389 Views)
Accepted by lightgoal
Perhaps you need to add a carriage return and/or line feed character at the end.
Bruce
Bruce Ammons
Ammons Engineering
(3,382 Views)
