Machine Vision
snap/grab and save to file
I have some questions about saving images to bmp(or jpg) or avi.
I just began to use LabVIEW Machine Vision, so please understand if my questions are somehow ridiculous.
I am working with NI PXI 1409 analog frame grabber and CCD monochrome camera.
Since the 1409 is attached to PXI chassis, I use Vision Acquisition Express vi in RT(Real Time) level.
So, when I try to save a single image or continuous image to file in my PC, it shows an error.
I am wondering if there is a way to save images to file on my PC hard drive.
When I set the path like C:\acquired image.bmp, no error occured and I think the bmp file is saved on the RT computer, not on my PC.
So, I am also wondering how I can access the directories of RT computer.
Thank you very much, in advance.
JY
Since I am just a beginner, I am looking into the labVIEW Machine Vision and Image Processing Course Manual.
(5,986 Views)
What is the error that you are getting? Can you post a screen shot of the vi that you have tried? Do you mean you want to continously acquire and save?
(5,975 Views)
Hi JY,
Can you FTP to the directories?  If you open a web browser and type FTP://ip address from your host machine, you should be able to navigate directories of your RT target.
Tejinder Gill
Visit ni.com/gettingstarted for step-by-step help in setting up your system.
(5,966 Views)
Hi Muks,
Yes. And also I'd like to save a single image to a file(bmp or jpg) too on my PC hard drive.
When I try to save a snapped image to a file, I could do it on the RT-target(not on my PC) and find the bmp file by FTPing the directory of RT-target. However, When I try to save continuous images to avi file(simple vi below), it gives me an error which I attach below.
Also, I wondering if there is a way to save images to file on my PC hard drive, not on the RT-target.
Thank you.
(5,959 Views)
Are you trying to read an avi and write back to the same file?
(5,944 Views)
Hi JY,
That error is being thrown because you cannot use AVI VI's on a RT Target.  That's because these VI's use DirectX, which is no available on RT.  You can take a look at the following article for more details.  There is also a workaround where you stream the data to your local machine and then save to AVI.
http://digital.ni.com/public.nsf/allkb/5C7A6FE2C2D49BE286256FE8007FDC35?OpenDocument
I hope this helps!
Tejinder Gill
(5,923 Views)
Accepted by jjunyoung18
Hi Tejinder G.,
I understand and I'll try the method you suggested.
Thank you very much.
JY.
(5,911 Views)
