Machine Vision
something about read bmp file
I want to read a part of a picture,for example ,a picuture ,what I only want to display in the front palette is that the center region of it?Which vision function
should I use?Thank you so much!
(3,261 Views)
if I use Image mask,only region out of ROI is black .I want the region out of ROI is cut off.
(3,260 Views)
Hi
You can do this with the use of IMAQ Extract function
Silver_Shaper | CLD
(3,257 Views)
