Machine Vision
spl2048-140km CCD imaging
I checked the manual, and 8 tap 8 bits is one of the valid configurations.  It is very difficult to figure out why it isn't working.
Did you end up getting a second cable so you have the full camera configuration?  If you don't have the second cable that could be your problem.
Posting an image when it is pointed at the light would be most useful.
Bruce
Bruce Ammons
Ammons Engineering
Message 11 of 12
(2,377 Views)
Thank you ,your advice is very useful.I'll have a try and contact you later.Thank you again!
Message 12 of 12
(2,373 Views)
