Machine Vision
taking two consecutive distance measures
Hello everybody,
i want to take two consecutive distance measures, let's say that first one is A and second one is B and then i have to do A/B
please find below the program
(4,743 Views)
here is solution check this vi
(4,732 Views)
Hi hatef,
i need to take two measures A and B so i can use the value of A and the value of B and do A/B , in the program that you sent, only the current value you can use and the previous one it's cleared
(4,723 Views)
you need just use shift register for this one
see this image and do it for your line lengh wire  data
(4,696 Views)
hi hatef ,
all what i need is saving the previous measure value " A " and divide it with the new measure B
(4,693 Views)
Accepted by topic author wajih7
this is two method for your request one with holding ctrl and plot two line roi
second without use ctrl for line
see two of them and choose with is better for you
best regards,
Hatef
(4,689 Views)
than you hatef
(4,682 Views)
