Home
Community
Discussion Forums
Most Active Hardware Boards
Machine Vision
Topic
Machine Vision
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
the trigger problem in vision builder
yanyan
Member
12-28-2005
10:58 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I want to ask is it must use the falling edge or rising edge to trigger the camera?Can it use when have a Voltage,then trigger it instead of by edge trigger?
Thanks for anyone who reply!
helen
0
Kudos
Message
1
of 2
(3,305 Views)
Reply
Re: the trigger problem in vision builder
ThSa
Active Participant
12-30-2005
08:13 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
it's possible to combine the framegrabber with an E or M-series card (which supports analog trigger) via RTSI!
Hope this helps,
ThSa
1
Kudo
Message
2
of 2
(3,293 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
