Machine Vision
threshold problem
hi
i try to make a thresuld to isolated  object but i have problem
after make a threshuld the image will be black all time what matter what is the throsuld value
i first read image from aqusition then convert it to gray then filter by use laplicaion then take a
threshuld value to separte object
i  read image from continuos aqusition from usb camera
any help
best regards
hi ?Q>
(4,423 Views)
Accepted by mangood
Right click on your image display and select the binary palette.
Regards
(4,401 Views)
Thank you so much
I have second problem
I want to remove this shadow before do threshold operation
how can I do this by use vision assistant vi
best regards
hi ?Q>
(4,394 Views)
