Machine Vision
using pulnix tm-1320-15 lvds camera with pci-1422 lvds and ni's icd file
The camera provider give me a custom-made-cable.
Its pinout configuration is based on the ni's wiring diagram. (not opened)
But because of the problem of power supplying, the serial communication pins cannot be used.
With the icd file for tm-1320-15 in this site, I cannot get an image, but only the error messages of "IMG_ERR_TIMO" and dma error.
So I've tried some solutions suggested in this forum such as acquisition image reducing(the result is noisy one) and moving the 1422 closer to the cpu board. But all failed with that message.
I doubt that there must be an only one setting for tm-1320-15 camera and camera configuration in MAX 2.0 in case of "serial disabled", or the icd file is not
proven in lvds version.
(Is "OnBoardClock(20)" right? the camera works at 25MHz according to its manual. )
Is there anyone succeeded in this combination?
(Thank you for reading my poor english. T.T )
(3,032 Views)
My problem is solved now.
But I don't know what is the exact solution.
The camera & cable provider and me tried as below.
try-1. connecting tm-1320-15 and 1422 with serial-enabled cable
try-2. changing 'OnBoardClock(20)' to 'OnBoardClock(25)'
With only 'try-1 ', it failed. but additional 'try-2' we could snap and grab the camera image.
And now, I can get images without serial-enabled cable, regardless of OnBoardClock speed.
I think the camera has been initialized with max's parameters(same as icd file) when the serial commnunication had enabled for the first time.
(I'll verify this assumption with new tm-1320-15 later.)
Thank you.
Tip : If tm-1320-15 and 1422 makes error because of parameter mismatching, reset the tm-1320-15's power.
(3,032 Views)
