Machine Vision
vision system design using 2 Basler line scan cameras
I would like to use 2 Basler line scan cameras (models L100 or L200) that I checked on the NI site as being approved. I would like to know how to acquire image data from 2 cameras at the same time and log this to the computer database.This is a high speed web application.
(3,499 Views)
Jack,
You shouldn't have any problem. You will need to use two PCI-1422 or PCI-1424 cards, since each card can only handle a single camera. You can use the RTSI bus to synchronize the two cameras. You will probably need an encoder for timing signals.
I am not sure what information you want to log to a database. If you are planning on storing the images, it could slow down your system, depending on the size of the images.
Bruce
Bruce Ammons
Ammons Engineering
(3,499 Views)
Bruce,
Thanks for the information. I am trying to develop a system to measure optical density of a web coating that runs at very high speeds - real time measurement. NI suggested the grayscale option, but I wanted to know about using multiple cameras to compare the web coating side to side.
(3,499 Views)
