Machine Vision
vision
This is meftah, Actualy I am new user with labview. my project is real time grading system of agriculture product using image processing techniques. Some one else adviced me to use labview. I am here to ask some quations in order to get your help.
Q1. Could I use Labview as fully programing with image processing techniques.
Q2. Could I use the aRtifecal Nural Network as Clasefier with Labview
Q3. What labview function can I use for Image resize (Example if that possible)
                               thanks alot for your attention
(4,934 Views)
Hello Meftah and welcome to the forums,
Yes you can use LABVIIEW and NI Vision Development Module to perform all image processing and pattern matching techniques.
Even though NI Vision Development Module Provides a very efficient color pattern matching , geometric matching with the and  "Binary matching using K-Mean clustering" , you can use this intro to create your neural network model:
Implementing NN using LABVIEW [link removed; article no longer available]
I recommend you download the NI Vision module first. After reading the concept manual and looking at the examples, you may reconsider another technique other than Normalization that I guess you currently consider.
Have a lovely day
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
(4,924 Views)
thanks alot my brother waled for the good answer but, the Q3 was not clear enouph, can you make it mor cosentrated if that possible
thanks once again
(4,909 Views)
Waleed has given a nice answer and i just want to add, there is a function called "Image Re-sample" you can use this for image resizing.
As waleed has said we will recommend you get VDM(vision development module) to access athe image processing functions.
(4,897 Views)
Thanks alot for your help you and waled I already got the what bout of you asked me and used it and got what I need.
my best regards
Meftah Salem
(4,855 Views)
Then please mark the reply as the solution.
(4,851 Views)
