Machine Vision
convolution crash (Vision2009)
 Labview 2009(Vision2009)  crashes when i use Laplacian or Smoothing kernel for Convolute.vi.
 I have installed Labview for several times in four computers.
And the result:
                       1. Vista sp1 32bit,     crash, 50 percent chance
                       2. Vista sp1 64bit,     not crash
                       3. Xp sp3 32bit,        crash
                       4. Xp sp3 32bit,        not crash
 So i replace the Files "Filters.llb", "FilterLLB.DLL" from Vision8.5. And it worked.  :smileyhappy:
帖子被martin1999在 11-05-2009 11:52 AM
时编辑过了
(4,347 Views)
IS this after installing the patch?
(4,330 Views)
I dont konw whether the Crash dependents on OS or not. So i  tried in different OS.
I am not sure if the patch is relevant to the problem.
(4,327 Views)
Hi Martin
So I ran your LabVIEW program and it didn´t crash on my computer (Vista 32 Bit SP2), so perhaps you should install the LabVIEW 2009 patch or install also the Microsoft SP2 for Vista
LabVIEW Base Development System 2009 - Windows 2000/Vista x64/Vista x86/XP - 2009 f2 Patch (32-bit)
http://joule.ni.com/nidu/cds/view/p/lang/de/id/1463
Kind regards
Beat
AE NI Germany
(4,288 Views)
