Machine Vision
Showing results forĀ
Search instead forĀ
Did you mean:Ā
convolution crash (Vision2009)
 Labview 2009(Vision2009)  crashes when i use Laplacian or Smoothing kernel for Convolute.vi.
 I have installed Labview for several times in four computers.
And the result:
                       1. Vista sp1 32bit,     crash, 50 percent chance
                       2. Vista sp1 64bit,     not crash
                       3. Xp sp3 32bit,        crash
                       4. Xp sp3 32bit,        not crash
 So i replace the Files "Filters.llb", "FilterLLB.DLL" from Vision8.5. And it worked.  :smileyhappy:
帖子被martin1999在 11-05-2009 11:52 AM
时编辑过了
(4,371 Views)
IS this after installing the patch?
(4,354 Views)
I dont konw whether the Crash dependents on OS or not. So i  tried in different OS.
I am not sure if the patch is relevant to the problem.
(4,351 Views)
Hi Martin
So I ran your LabVIEW program and it didn“t crash on my computer (Vista 32 Bit SP2), so perhaps you should install the LabVIEW 2009 patch or install also the Microsoft SP2 for Vista
LabVIEW Base Development System 2009 - Windows 2000/Vista x64/Vista x86/XP - 2009 f2 Patch (32-bit)
http://joule.ni.com/nidu/cds/view/p/lang/de/id/1463
Kind regards
Beat
AE NI Germany
(4,312 Views)
