Machine Vision
which algorithm did the .image function has been used
hi ni
i have implement some image function like remove small object,
and particaler analysis to find area and perimeter of object in binary imge
can any one pelase tell me which algorthem that have been use by labview to find thease two feature or value?????
best regards
hi ?Q>
(4,197 Views)
Accepted by mangood
It sounds like you would want to use the Particle Filter and Particle Analysis steps in Vision Assistant. Vision Assistant is part of the Vision Development Module (VDM). The steps I listed are found in the Processing Functions: Binary section of Vision Assistant. The Particle Filter can remove small particles that are not of interest. The Particle Analysis can give you counts and measurements of interest. There are other steps in the same section that may also be useful for you application.
Cameron T
Applications Engineer
(4,180 Views)
