Machine Vision
why doesn't my vision program work as an executable?
You could also use shared variables which have a scope that can be cross-process. Because data is marshalled in that case, though, expect performance to be quite different compared to when everything is in-process.
Message 11 of 12
(2,756 Views)
I apprecate the advice, but i was trying to not re-write the existing executable, just work with it.
Message 12 of 12
(2,746 Views)
