Machine Vision
working with color images
hi,
i am stuck on this program i can't seems to figure out.
can someone please guide me to the right direction.
i made this program, and it is correctly take a reference picture, and other rotated pictures and draw crosshairs while the images are rotated.
it is working.
but when i put a COLOR picture instead of grayscale picture. it doesnt work. it gives me error.
can someone please help me with this
i need to build with vision assistant  this script
it only seems to work with grayscale images and not COLOR PICTURES.
what can i do to make it work?
I need to work with images like this and i need to draw crosshairs around the BLACK DOT to the left corner.
I also have a sample vi created from vision assistant?
Message Edited by krispiekream on 02-24-2010 04:37 PM
Krispiekream
(3,639 Views)
Accepted by topic author krispiekream
In vision assistant follow this
Do this if your starting image is a RGB one.
(3,624 Views)
I have built a script for the color image I have.
My vision assistant is a trial version, so I cannot create the subvi for labview.
Do you think you can help me?
I can send you the script and the reference template along with the 1st image.
I need to show that this work so that I can go ahead and purchase the full version.
OR.
I created a script in trial version of vision assitant 2009.
my co worker has full version of vision assistant 8.5.
can i save script as version  8.5?
everytime i open script of 2009 with 8.5. It doesnt work.
thanks
Message Edited by krispiekream on 02-25-2010 10:51 AM
Krispiekream
(3,615 Views)
I am having lv 8.0. So if can clearly post the steps and images i might be able to help you out.
(3,599 Views)
