Measure
キーエンス NR600とのコネクション
こんにちは。
現在NR600を使用したデータ収集をLabVIEWに取り込んでリアルタイムで解析しようとしています。
メーカーサイトからドライバ入手し、Labviewへの組み込みは成功しておりますが、NR600が認識されません。
NR600とPCでの収集はできており、コネクションは出来ているのですが、Labviewからは見えないようです。
これはどこに問題があるのでしょうか。
(5,726 Views)
Hello suzuki200
Did you try to detect it from NI MAX?  If device does not appear in LabVIEW but appears in NI MAX, then I suggest you resetting the device from NI MAX and trying to acquire data from LabVIEW again. The problem might be caused by Windows version and Keyence DataPlugin for Keyence-NR driver
compatibility as well. Below you can see windows versions compatible with Keyence-NR driver, if you aren't using one of these windows versions then the issue might come from there.
Windows 7
Windows 8.1
Windows 10
Windows Server 2008
Windows Server 2012
If you can't detect the device from NI MAX, then try to uninstall and reinstall the Keyence-NR driver again.
Regards)
(5,670 Views)
Thanks for replying to my question in the comments.
I tried to detect it from NI MAX, but it was not recognized.
I am using windows 10.
I also uninstalled and reinstalled the NR driver, but nothing changed.
Am I doing something fundamentally wrong?
(5,630 Views)
Hey suzuki200
In this case, because of the third-party hardware, I suggest contact with Keyence support to help you troubleshoot the issue in the best way.
Regards)
(5,614 Views)
Unfortunately, Keyence's answer was below.
"Keyence does not provide any support regarding this software, such as how to use this software."
Other methods are currently being considered.
Thanks a lot.
(5,572 Views)
Hi suzuki200,
Yes, it makes sense that they can't provide any support regarding driver, but what I want you to connect them again and require support regarding troubleshooting your hardware to be sure, that the problem isn't coming from the hardware. I am sure that they can provide any support regarding the hardware. Let me know about any news.
Regards)
(5,534 Views)
Thank you for your comment.
When I confirmed with Keyence sales, it supports up to Windows 7. is what they said.
I will give up real-time measurement using KEYENCE NR.
(5,374 Views)
