Measure
Adding a Device: -201401. Make sure device is connected?
I have been able to set-up my Measurement & Automation explorer to detect my device (NI cDAQ-9188), but I'm having trouble adding the device.  The error statement states:
Add device has failed.  The error report from the device driver is as follows:
Add device
-201401
Retrieving properties from the network device failed.  Make sure the device is connected.
How do I resolve this issue so that I can test my I/O modules?
(10,179 Views)
Please post in the appropriate board or ask the moderator to move this. This board is for an obsolete program called Measure - an add-n for Excel.
(10,163 Views)
Hi wmm26,
One of the possible causes is not having the correct DAQmx driver installed on your system. What version of DAQmx are your currently using (the most recent and the one you probably want is DAQmx 9.8). Also what operating system are you using?
Thank you!
Anna L
(10,161 Views)
Accepted by topic author wmm26
DAQmx version: 9.7.5
Operating System: Windows 7 64-bit
Initially:
In the Network Adapters tab it reads:
- No network adapters found
In the firmware tab it reads:
-  firmware version: 1.1.0f0
Based on the status of the network setting tab, I assumed my problem was related to the network connection.  I reset my network adapters and this seemed to resolve my issue.  Thanks for your help.
(10,147 Views)
Sorry about this.  I will contact the moderator asap
(10,145 Views)
