Measure
I need a help.. in obtaining plots for diffent inputs in single graph
I created a VI for a particular equation using  blocks  within a' for' loop. external to that, inputs are given.For a particular  input(constant) i obtained the graph correctly.But my problem is that i want to plot the graph for more than one inputs ,i.e. after calculating with first input, the second input should also be used. I tried with arrays but it dosnt works due to the indexing .can any one help me please...
(5,815 Views)
This board is for an obsolete product called Measure - an add-on for Excel. Please post to a more approriate board.
(5,787 Views)
