Measure
The waveform of the 2400 Source meter has noise
Hello everybody, I have a problem with the Source meter. I think the output of the 2400 Source meter have a problem. I used the Oscilloscope to check the output of the 2400 Source meter. I saw the waveform, the waveform has noise. Why it has noise. How can I set up so that the waveform hasn't noise. Thank you very much. Best regards Van Phu
Best regards
Van Phu
(5,875 Views)
Why are you posting here? The Measure board is for an obsolete product called Measure - an add-on for Excel. It does not sound like your problem is related to any NI hardware or software.
(5,871 Views)
