Measure
Beckhoff CX8091 works with the SCADA OPC-UA
Does anyone had a experienced of working with beckhoff CX8091. I want to know, how beckhoff CX8091 works with SCADA OPC-UA. i did know about the siemens PAC 3200 working with SCADA OPC-UA, but didn't find any good material regarding beckhoff CX8091. I shall be very thankful, if anyone can help me out in this regard.
Kind Regards,
Usman
Message 1 of 10
(10,231 Views)
You posted to the wrong board. This is for an obsolete product called Measure - an add-on for Excel.
Message 2 of 10
(10,215 Views)
can you please tell me, where should i post this Question.
Message 3 of 10
(10,212 Views)
What programming language are you using?
Message 4 of 10
(10,205 Views)
Accepted by topic author usmania
i am not using any programming language. i only have to check/see that these to system could be interface or not
Message 5 of 10
(10,177 Views)
i am using IEC 61131-3 prgramming language.
Message 6 of 10
(10,171 Views)
If you aren't using any NI hardware or software, then there is no point in posting questions to the NI forum.
Message 7 of 10
(10,150 Views)
p.s. The IEC 61131-3 is a standard - not a language.
Message 8 of 10
(10,147 Views)
i am using TwinCat PLC programming on this task.
Message 9 of 10
(10,136 Views)
You should be talking to them. Nothing on the NI site applies.
Message 10 of 10
(10,126 Views)
