Measure
High Resistance Measurement with nanoamps current source
Im working on semiconductor-based sensors & needed to measure the sensor resistance.
The range is from around 2G to say 50M.
I plan to use the 2-pt method of driving a constant current say around 100nA & then measure the voltage across the sensor. Having a variable current source would be better to plot the V-I characteristics.
So is there a card which possibly can integrate the nA current generation & voltage measurement together? or do either of functionality?
Also is there any way to measure currents in nA range?
Hope for some inputs.
Mehul Raval(MSc),
Dept of Instrumentation,
Indian Institute of Science,
Bangalore-560012.
India.
(6,720 Views)
This is a duplicate post. Please refer to the thread found here. Thanks.
Kent L.
(6,705 Views)
