Measure
I am unable to retreive data using the capture task.
I am upgrading our production network analyzers from the old Agilent 87xx versions to the E5062A version.  I have a VBA macro written to take care of automation.  The only change that should be made is to update teh SCPI commands in the capture task window in Measure.
I am able to send SCPI commands to configure the analyzer setting automated, but I am unable to retrieve the trace data or the marker data.  I know the command is O.K. because I used the "test" in the edit instruments and the correct data was returned.  The delimiter has also been set already and 000/010/EOI is returned while performing the "test" in edit instruments.  The only response is:  Timed Out, Waiting for Data.  Am I missing something?
(6,858 Views)
Emrsn-
Which software are you using to test your GPIB commands? Do you get a response when you send the same commands to the 87xx devices? You might want to double check and make sure that bot hinstruments respond to the same set of SCPI commands.
(6,850 Views)
