Measure
Instrument driver set as RAW device when it should be an INSTR device.
I accidentally used the Driver Development Wizard to install a function generator, Tektronix AFG3102, through USB as a RAW device. Now nothing is able to communicate with the function generator. I have been unable to change\delete this driver. Before this the Tektronix ArbExpress software was able to connect to the function generator, now the device does not register.
(6,597 Views)
In the windows\inf folder, you can delete the inf and pnf files that were created by the wizard.
p.s. In the future, you will want to post to a more appropriate board (i.e. Instrument Control). This board is for an Excel add-on program called 'Measure'.
(6,591 Views)
