Measure
Load cells and non contact strain measurement
I am designing a bi-axial machine which meant for a fatigue test.
Could someone recommend me where to get a dynamic load cells and as well non-contact strain measurement?
Thanks.
(7,648 Views)
Hi Alvin788,
Do you presently use any hardware to measure these or are you enquiring as to what hardware/software you will need? Are you planning to use LabVIEW? The following three links talk about measuring Load Cells as well as Strain Gauges
Continuous Acquisition from a Smart TEDS Load Cell Sensor
How do I Configure a Load Cell in MAX?
Strain Measurement with a Strain Gauge
This post will also be highly helpful.
(7,636 Views)
how to you acquire strain signal in a specimen rotatiang at 4200rpm.because in fatigue test the specimen will be rotating.
mpsingh
(6,562 Views)
