Measure
Signal speeds
Hi guys ,
I have a daq 6008 ,measuring rotational speed with a hall effect proximity . I have tried connecting it the three way I can with the 6008 . ie. Digital I/o counter and analogue voltage input. The input is used to fire a timer to perform calculations.
the counter dost work atall really, I know its only an event counter but the counts are never the same as the rotations. When useing the digital input and the speed increases it input misses pluses .
The analoge input , the proximity is switching 12v to the analogue input , I have the vi set up to read after 2v due to noise at around 1v, the problem is when the rotations increase the switched voltage drops , and alto above 2v the daq dosnt see it , is the daq not quick eggnog's or am i missing some code that i could use .
thanks for any advice
Message 1 of 8
(7,871 Views)
Dear Vadajooz
There is a very similar forum post and a solution to what you are trying to achieve at the below URL:
http://forums.ni.com/ni/board/message?board.id=170&message.id=400251&requireLogin=False
Let me know how you get on with the VI they posted and if their advice helps.
Message Edited by david.bolt on 04-06-2010 07:33 AM
Many thanks for using the NI forums and I look forward to your reply.
Kind regards
David
National Instruments UK
Message 2 of 8
(7,845 Views)
hi david , that link goes to my profile ??
Message 3 of 8
(7,756 Views)
Dear Vadajooz
My apologises, here is the forementioned link:
Kind regards
David
Message 4 of 8
(7,745 Views)
ok thank you ,
i will try it and see what happens , my daq is dead at the moment , so it needs to go back to the shop !!
Message 5 of 8
(7,743 Views)
Thanks for your reply Vadajooz.
You should contact your local National Instruments office if you bought the device from us whereupon we can repair the module if deemed faulty. Thanks.
Kind regards
David
Message 6 of 8
(7,740 Views)
i have done , i opened a service request and have been in contact with ni . any idea how long it could take ?
Message 7 of 8
(7,738 Views)
Unfortunetly I cannot quote estimated delivery times. The engineer dealing with your servcie request will be able to advise on this. I look forward to hearing how you get on with the advice from the other forum.
Kind regards
David
Message 8 of 8
(7,735 Views)
