Measure
Strain Gage - value draft
Accepted by topic author Žiga
Hello!
I decided to test full bridge configuration on NI 9237 card with resistors while I wait for equipment. So I made Wheatstone bridge with four 120Ohm resistors. Crimped all four exits in RJ50 connector and plugged into card.
The thing works! I got no drift present and I didn't even usen precision resistors. So this test eliminates all errors associated with NI card and carrier.
Žiga Pristov
Message 21 of 22
(3,669 Views)
Hello!
I modified my equipment for using a full bridge configuration. Looks like the full bridge solution is the right solution for this problem.
The measuring system currently works fine for my application.
Thank you for all the help!
Žiga Pristov
Message 22 of 22
(3,628 Views)
