Measure
Unexpected error in MAX
I have been receiving the following message in MAX:
The imaqcfgui.mxx plug-in caused an exception in the CmxAggregateItemUI::FinalRelease function in the NIMax process.
See these files for details:
C:\ProgramData\National Instruments\MAX\Logs\20110218_160326-NIMax-0000129C.log
C:\ProgramData\National Instruments\MAX\Logs\20110218_160326-NIMax-0000129C.dmp
I use a PXI-1044 chassis in combination with a Windows 7 operating system (everything was functioning fine under XP)
(6,338 Views)
Dear Stizo,
please find the MAX part under the following link . You can also try to delete the entire MAX databases .
Hope this helps,
Martijn S
NI Netherlands
(6,330 Views)
